Frameworks reset buttons...
Have had quite a few lanes where the bowlers reset button sticks,wont come back out so you get cycling,etc.What i did was...i used some 3/8 foam rubber w/tape on one side,cut it into 2 small pieces,popped off the button top,stuck the tape under the button.,and re-installed switches.Foam tape keeps it from twisting around in the oval hole and gives more push to stay out,no more sticky buttons so far! Kinda got tired of tossing buttons once thought of as bad.I use black window insulation foam rubber,single side tape.Keeps it from twisting ,simple and quick to put on.(HIGH linedge house). F.Y.I.Tags: None
Members
- Mar 2000
- 784
- A-2,Amf,GSX
- Frameworx
- Kegal phoenix-s and A-22
- Brunswick Pro anville
- 1971
Re: Frameworks reset buttons...
Blackout-If you contact brunswick they will send you out some peel and stick plastic squares.You remove your button and stick one square on each side so the button and that will help keep them straight,we also installed a micro switch spring behind ours so that they pop back better.The new buttons have a ridge on both sides to prevent sticking.Are These things the worst or what!!We have also burned up many solinoids because of them sticking.What was wrong with the little round reset buttons we used to have?I forgot you could buy them at the hardware store and they rearly failed.
Yuppers.They should have stuck with the round reset buttons!!NO real honest reason to change from it that i see.Engineers/designers....they love to change things,but is it for the best? lol
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
