Fustat Fuses
  • Fustat Fuses
    The boss asked me today to try to find an alternative in the way of a Mod to replace the Fustat Fuses in our SurePik Ball Returns
    As we are in Australia and these things are a bit hard to get hold of and quite costly
    This raises some questions
    1 Has anyone replaced them with an alternative
    2 Why where they used in the first place (they sit beside a 3ag fuse and holder
    Fustat protects the belt Motor the 3ag protects the hand drier blower)
    Was thinking about some sort of reset type setup (simular to what they use in aircaft) bearing in mind we are running a 240 Volt system
    I want to just put in a household C/B but room is an issue
    Any Ideas??
    Here's a place for circuit breakers.
    http://www.alliedelec.com/search/sea...romsearch=true
      Same vendor, but pop-out style choice.
      http://www.alliedelec.com/search/sea...FQQaQgodDFumMA
      I do like the size PJ searched.
        I have heard of fustat fuses that are modified similar to breakers where they can be reset. With the technology these days its not surprising. The basic of the fustat was the early days of over-current protection on the edison based electrical system. They were sized differently so you couldn't put a larger size fuse on a smaller designed circuit. There are adapters available to up-size or down-size and they are even modified to be temporary or permanent. I wouldn't recommend these unless you are comfortable with electrical design or the protected circuit in question. Switching over to a newer breaker is a great idea and taking in mind that the circuit is a motor load which could be slightly over-sized or slo-blo/thermal protection I like PJ's choice as well.
