Omega Tek MK70 schematic / Circuit layout
  • Omega Tek MK70 schematic / Circuit layout
    Looking for MK70 schematic / Circuit layout or drawing. I downloaded the manual from Stahls and it references an apex Circuit layout or drawing of the board but its not there or online anywhere I have found. Im looking for a repair drawing like was put out on the old 5 boards in the gray manual / book . If you have that drawing or have made one ...lol.. please share thanks in advance.!
Help-broken Part
Greeting all.
Thanks for looking.
Bolton454
Pin Damage
Making TDM's adjustable.
1:1 shaft wear
