82/70 chassis problem
  • 82/70 chassis problem
    What inside chassis controls foul cycle have chassis with no foul cycle chassis has single omeg tech board it is not a mp chassis it has green Elco plug have changed multiple boards
    If the problem stays with the chassis you should look at C2A pins 17d and 12F. This is where the foul signal enters the chassis. If the pins are ok you will have to follow the wiring to the main board.
    To answer your question the foul signal is controlled by the omega tech board and i believe there is a jumper to select foul or no foul.
    Preventative Maintenance - Vector HD Problem
    Tried to help a friend out at my old center with an electrical problem. 24 Brunswick Jetbacks, Serial 3000, no TDM with Vector HD Scoring which I know nothing about other than...
