pinsetter dropping pins
  • pinsetter dropping pins
    when pinsetter is setting pins they just fall all over the floor then after a few cycles it is back to normal. micro switch on cam? which switch is it. amf 8270
    my guess is its table drive or solenoid not releasing gap too small or a broken pin on the drive
    im never wrong just askme
      Spotting, or respotting? i.e. does it happen when setting a full rack for 1st ball or are pins dropping out of the fingers when respotting for 2nd ball?
        When it sets pins you say they fall over?’ Is it 1 or 2 pins? All of them? When they don’t fall over do they wobble a bit or is it a perfect spotting action?
        If pins are falling over very unlikely (whilst not impossible ) that it’s a switch, it’s more than likely going to be a mechanical issue somewhere.
