Table problem
  • Table problem
    I have a table every once in awhile on a spare it’s real jearky sometimes will interlock
    Have you tightened up the table drive? Very well could be a bad or broken tooth in the gearbox too. Might be a loose terminal on a micro switch too.
      I will check these all out thanks.
