need part number
  • need part number
    82/70 cast table , need part number for lever that connects 7 pin respot cell to wire channel
    New fixed link or old style with long carb link to 7 cell?
      Presuming you have the wireway directly connected to the cell.......
      070-007-620 If you are using the larger 5/16" pivot studs.
      Or you can use 070-007-618 (for all the other cells) and lightly tap the flanged bearing out of the arm (the pivot stud works great for this) and reinstall it with the flanged part on top,
      -- Larry
        old style, the one spare i had was alot beefier , for the life of me i couldn't find in parts book, long carb link to rspt cell
          610-704-026. Is the lever for the old style.
            that one has a bend in it ,the one i need is straight , it attaches to the end of wire channel and table with carb link stud right in the middle
              You need 070-002-708 Link Assembly, Respot.
              (82/70c Parts and Service Manual pg. 28-29 Item 38)
              In all honesty I would convert that setup to the late version that directly connects the wireway to the #7 cell. You would have to replace the wireway, but it greatly simplifies adjusting the cells.
              -- Larry
                and we have a winner!! thank you so much .
