Respotting 90XLI
  • Respotting 90XLI
    Hello
    I have a problem with a lead.
    During the 1st cycle, the pliers do not take the pins that remained standing.
    I tried to play with the respotting rod, but nothing happened.
    If any of you have any solutions, I’ll take them.
    Do they close and just allow pins to slip through, or are they not closing at all?
    9th Amendment!
      They close, but when the table rises the pins fall
        You might have a tight respot cell. Check your 2” adjustment failing that check your linkages and even check your pawl gap adjustment for 1/8 on ally & steel table (version 2) or 1/4 gap on steel table version 1
          Thank you for your help the problem came from the clamps
            On our XLI-edge’s sometimes the white ski’s/finger nails on the end of the fingers are damaged and that will cause the fingers to hang up and not close and not pick up pins.
              That's good to know, thanks
