Table casting mounting hole worn out by 7 area.
I have a lane that all sudden the sweep keeps catching the 7 cell when runs by and also the pins way off spot. So I went to flag the table and noticed that the back mounting bolt by the 7 side was pulled threw the table casting, and table crooked. The hole is worn out. Is there anything I can do to rig it to work, or do I need to buy a whole other table casting?Tags: None
- 1 like
Members
- Nov 2012
- 199
- 82.90, 70XL, 70XLI & GSX
- 3QT/BES, BESX, BOSS
- Express model B
- Synthetic
- 1993
I’ve seen some things go wrong over the years but this is a new one for me. I’m struggling to understand how that could happen even if it was a little loose. Might get away with a washer and grind it down so it fits snug in the table slot
Member
- Aug 2003
- 2686
- 82/70, 82/90XL, A2(27:1),
- AccuScore Plus
- Kegel Flex Walker
- DBA IQ/Pro Anvilane
- 1973
Originally posted by Ausweegie View PostI’ve seen some things go wrong over the years but this is a new one for me. I’m struggling to understand how that could happen even if it was a little loose. Might get away with a washer and grind it down so it fits snug in the table slot
I have a table like that.
I just used a longer bolt and heavy washer under the hex head. The bolt head does stick out under the table casting but it's secure.
I have thought of designing an elongated washer that would fit into the pocket and still allow the bolt to move in the slot as needed for adjustment.
-- Larry
Ball Returns Shorted Out?
Trip rocker arm
Lower ball cushion board
Backend motor plug
82/70 combi motors
