starter pad spring tentioner 82-70
  • starter pad spring tentioner 82-70
    Re: starter pad spring tentioner 82-70
    light ball's go in better
      Lane 1-2 had more then a lot of b.i.e .Starter to hard for
      the light balls to push
        Interesting. I don't recall seeing any starter pad modifications other than the grommet head on the arm behind the rail. I've never really had light ball problems except when the paddle keeps batting the ball back into the pit before the kicker can grad hold of it.
          daprhb
          Reduction pulley and spring shock. A very CHEAP fix for that.
          Ron
          Real cool mod.
          On my machines I just glued a rubber pad to the arm sitting against the uprail. Caused the pad to sit a little farther back. And the balls didnt have to push it as far.
            Spring broke,Put brannew spring on and it was tooooo hard.
              Thanks Old School. I thought I had recalled a reduction pulley. but wasn't sure. It's only been a marginal problem, but I may just try that.
