no mask foul lights
  • no mask foul lights
    I know there's a diode on the mk-70 board that can blow and you'll lose first or second ball light in the mask. What would cause the foul mask to quit working. Switched chassis and I know the problem is there. In the last week I have three lanes lose this light, right after I installed the new LED's in the second ball. Please help.
    Joshua Knight - Stand By A Mechanic
    USBC Open Championships El Paso, TX 2015
    Well, obvious things first....
    Does it run a foul cycle/score a foul but not light up the foul light on the mask?
    Is the ELCO plug in all the way, are there any spread or broken pins at this connection?
    Does this problem only follow certain Omega Tek boards?
    There is a varistor on the bottom of the board for the foul indicator, dont know exactly where but its there.
    As a first response to this I would say check the green ELCO plug, this is where the mask lights go through and a common problem of this connection is the pins on the motherboard will spread and not make contact with the pins in the plug, I usually have this happen with the 2nd ball light. I dont remember exactly which pin is for the foul but since there arent that many you can take a small screwdriver and gently close the pins on the motherboard a little, this will help it make a nice tight connection when the green plug is there.
      Most of the 'newer' MK-70's have electronic self resetting 'fuses' in them. Older ones have actual fuses - these are called 'pico' fuses - they are usually green and look like a 1/8W resistor. These are at the bottom of the board (component side) right above the boards edge connector (ie: where the board plugs into the chassis slot). Just take a meter and check for continuity across the fuse.
      I'll post a pic in the morning of the board and the exact fuse to check - I'm pretty sure it's on the right side of the board.
        What the heck, I'll do this before I hit the rack
        Here is the 'pico fuse' version:
        Here are 3 variations of the auto resettable fuse types:
        Both of these have full pindication capabilities.
        This one is set up for only 1st ball, 2nd ball, strike, and foul.
        From the bottom right 'facing' the board - going right to left - the 1st one is for foul, 2nd - strike, 3rd is for second ball, and the 4th is for 1st ball light(s).
        Hope that helps. BTW - the fuses are usually rated at 1A - both types. If you need to find a source - let me know.
        Jon
          I thought it was something else, cool I just learned something new!
            We have the Pico version. I checking the Elco connection first. All seem to have good connections. Can you put a meter on the pico fuses to see if they are good. The last time I had a mask problem I blew one of those but you could see it. With a visual inspection of the board I can't see anything wrong. Has anyone use the LED mask lights from ZOT. I put ten on one side and the house (only second ball light) and haven't had any problems. When I order a second set of ten they sent me a different bulb. Would fit so they found me one that would. Installed them all and then I start getting told my foul indicators aren't working. I was 4 lanes now only three. I think lane 3 just had a bad connection. Does anyone know which Pico fuse would be for the foul indicator. OH yea the machine reads the foul just no indication light.
              Jon
              Does your left to right apply to this version
                Opposite way mechwin he is going RIGHT to LEFT.
                  sorry my bad. use to reading left to right I guess
                    The pico fuses often don't show any visual indication of blowing, so just check them with a meter for continuity.
                      Since I posted the pics of the various versions of the MK-70, just for the fun of it, here is one that has a couple of extras that come in handy:
                      LED's replacing the input diodes so you can visually 'see' the various inputs as the machine is cycling.
                      LED's for pindication (great for those who still use gripper wires!)
                        wb8yjf thankyou, I have not seen one of these for a long, long time. Excellent pictures.
                        maister
                          Replaced the pico works good now
                            Quite funny for me that this topic should come up, as I also have 1 lane that doesn't display foul on mask board. Thanks for the pointers everyone.
                            If it ain't broke don't fix it
                              Deck Lift Gear Damaged
                              Starting Issue, Random Cycling of Pinsetter
                              Noticed that the Rake Crank Arm had a jerk/stutter on 2nd pass of 4 phase movement. Hand cranked to movement point and felt solid...
                              Streamlane Mask Halo Lights
                              Baddest Tool Chest In Town
                              Adios, motor boater!
                              Aluminum Repair and Welding
                              http://aluminumrepair.com/...
                              Hi, guys.
                              check this jam...
                              the ball stuck the table up
