does anyone have a good and easy to follow call sheets for the back to keep track of the calls.thanks for any help
call sheets
The BEST call tracking sheets by far are from a guy on here called Andrew, his program is called Parts Tracker, you can track calls, parts orders and parts used etc, all maintenance work done etc there is SOOOO much you can do i SWEAR BUY IT......AS REQUESTED....The all new and VERY improved "super cool" Pin_Head with super hip shades.....
