82-70 with MP Chassis. I have a Westinghouse table motor that continues to run. While standing there I can hear the Klixon click but the motor continues to run. I can reset the Klixon while it is running. The motor gets real hot and keeps running untill I unplug the motor. I was called to the machine for a continuous table. If I zero the chassis it still runs. What would allow this to happen?
Continuos Table
if your klixon is clicking out and the motor is still running id surmise you have some internal arcing/ wirecrossed inside the motor. the klixon is supposed to shut it down before it gets too hot to damage itself.
i've never seen it happen on my nationals but I suppose you could have you cent mech broken in the "run" position?
somebody mentioned the stator's run windings can get stuck in this thread here:
http://www.bowltech.com/forums/showt...t=westinghouseWhen you know what to do, everything is easy.
Does replacing the stator cure this issue?It could very well be what Grit has said, one of the windings has let loose shorting the motor.It finally went in the trash.70's MP/PBL/LBS,Q-Score
Prolane Walker sport
Someone has probably wired around the klixon "Darn motor kept turning off until I fixed it".
If the Klixon was in the circuit, the motor wouldn't run when kicked out. Personally, I haven't seen an internal Kilxon short out and still kick out. But I have seen a broken plastic Klixon housing cause anything..
