So this happened out of the blue, well you could check the table/table cable and plug also pull the cover off the front wireway which is where the table cable goes into the machine and this is where it connects to the TAC board. Check there for anything obvious like loose wires or metal debris laying on the board, etc, then from the TAC board the table wires then go to the C2A plug, so you could follow them to there as well. The table cable has 13 wires if I remember correctly, 10 for the cells, 2 for the GP switch, 1 for ground. But since it only reads these wires are grounding when the table cable is actually plugged into the table, then the problem should be on the table....damaged wires, messed up table plug or pins in the plug, etc. Table wires totally suck but if you have a little patience they are not so bad. If this started happening after a recent 'traumatic event' that the table has experienced such as a nasty table jam on the 7 side, I would be suspecting the table cable/plug area.
