82/70 SS chassis, National motor with AMF -044 start switch.
Runs fine except when it does an auto offspot it trips the curtain wall breaker. C1 looks good, tried different relay, sweep run and reverse switches, different chassis, and the os lever gives the sweep plenty of time to reverse up, pause, then run to zero. Sometimes the breaker trips as soon as the relay engages and sometimes it trips when the os lever goes back on the switch. This was installed nine months ago and worked perfectly until tonight. No obvious wire issues with the relay or switches. I did notice that when it trips the breaker the spider relay arcs brightly, normally there is no arcing at all. Manually running the sweep in both directions works fine and the motor gearbox has not had any issues. The arcing is telling me something but im not sure what that would be. Wondering if it could be the start switch or sweep capacitors. Anybody run across this before and what was it? For now I have the relay turned off so the machine runs but I would like to fix this and get it working properly again.
