I have a problem with 6 Chassis,swith no 1st or 2nd ball operation, Have tested all chassis,s with a known good Omega-tec PCB and a test
1st/2nd ball LED Test plug all no go! all other chassis,s (10) Tested out ok
82-70's
Computor Score
Elco/Omega Tec
PBL's
Express CE Oxyshock/Versitity
16 Wood
No pindication
a few things i have had take out the 1st/2nd ball lights:
1.something fall into the chassis by the heat sink with the three diodes.
2.A bad diode
3.a bad klixon
4.bad pins in the green plug either side
Another possibility to add to the list. Earlier this season I had a chassis (MP), where all my circuits in the chassis for ball lights tested good. After doing research of the chassis schematics, found that it's power source comes from the T1 transformer, I changed the transformer out and regained the masking unit lights.
