SS chassis problem
  • SS chassis problem
    Chassis has New T1 & T2 Transformers, New Varistor's,new diodes,New Contactors
    All wiring checked , right voltages
    Back-end Motor starts and runs ok.pit light ok
    New Omega-tec PCB
    No Cycle
    No power to Sweep or Table at micro switches ??????
    What am I missing
    82-70's
    Computor Score
    Elco/Omega Tec
    PBL's
    Express CE Oxyshock/Versitity
    16 Wood
    No pindication
    M cube or instructomat sounds like possibilities.
    70's MP/PBL/LBS,Q-Score
    Prolane Walker sport
      Fuses?
        if you have no power at your sweep and table microswitches then I would suspect that something is grounding out in your C2A plug, maybe you have something rattling around in the bottom of the chassis? also take the botom off and make certain that all your ground wires are connected properly.
