How hard can it be ?
  • How hard can it be ?
    Ok
    someone smarter than me needs to invent this.
    We need a simple relay box made to read brunswick frameworks scoring data from its ccd camera to tell 8270s to run strike cycle or respot pins.
    The pinspotter side of things is easy ground or no ground . but hot to convert brunswick data i have no clue ?
    for years we have all heard it cant be done ? will one of us out here in bowl tech land take this problem on and slove it finally ?
    we dont need anything fancy like sweep rev on misses or 7-10 picks . just a box that will open a ground circuit when a strike is bowled!
    again how hard is that ?
    so bowl tech i leave this problem to you ! someone smarter than me please invent this . so no one has to suffer with table wires any longer?
    thanks
    Use an AMF above ground ball return camera on a hoop and have that send data to the MP or Omega Tek Board.
      Im not sure in that type set up if a amf camera can work with out a amf cwc or cpu.
      i am hoping someone has the answer using the ccd camera and amf ground circuit .
      thanks
