90xl distributor
  • 90xl distributor
    I was just wondering where the back support post height should be
    Kustodian/C RBD Spray time on 4/ distance 24
    Max 20 Cleaner Infinity Oil
    not have an exact distance, must be level and have little patience after you fall to see how the pins of the wheel
    I am born to be a'live!
      You'll have to guage the distributor height off the bin at the bolt head for the bin switch. It should have maybe a 1/4" clearance. The back slots mounting it on the elevator frame are primarily for leveling the dizzy. Take off the springs and see if it favors one side. It shouldn't.
        All the leveling is fine nothing thats to bad just been wondering
        Ill check to make sure it has the right clearance.
        thanks
          If it needs raised, the back end could have been installed too low. The clearance is raised by adding washers to the bottom of the mount arm where it hooks to the crossbeam. (2 1/4" bolts)
            Ok understand what you are saying makes perfect sense.
            thanks
