ss chassis burning up 3 board table triac
  • ss chassis burning up 3 board table triac
    Hi
    I have a chassis that will run about 3 mins then Burns up a component in the omega board and I get a continuous table run?
    I put a old set of 5 boards in andit smokes the big resistior above the sweep and table triacs on the 3 board . Then I get a continues table run?
    I believe there is to much voltage going to the table circuit on the 3 board but what would cause this problem??
    Thanks in advance
    Everytime I have had this happen is was because some of the wires that connect directly to the motherboard, where the pins are soldered on top, were shorting because a nut or screw fell in there.
      Nothing shorted????????
      Does anyone have a idea of what component going bad would cause this ?????
      Thanks all
