RE: Bounce Boards
  • RE: Bounce Boards
    What revisions/parts/mfg. for bounce boards are being used? The norm seems to be 2 channels, 2 t-bars, 1 angle. Anyone found a better way?
    Thats what I use with no problems.
      I have had good success with that setup plus using the 090 boards and 5/16 bolts instead of the 1/4
      70's MP/PBL/LBS,Q-Score
      Prolane Walker sport
        Same here.
          Yeah I do exactly teh same and I'm with you guys the 5/16" bolt is far better than using a 1/4" one..
            We always used 1/4" GR 8 with Flexloc nuts and medium strength Loctite ( #242 ). We did go to GR 5 1/2" bolts installed with #242 and a 1/2" breaker bar in the bounce board brackets.
            The 5/16" bolts make sense.
              1/2" bolts on the bounce board itself? Or do you mean the bracket in the machine, you up sized the 3/8 hole to accommodate a 1/2" bolt?
                The 090 bounceboards have larger holes in all the locations except where the vibration dampeners go to accomodate the larger bolts.
                  I never understood why the T-bars stopped short of the entire length of the bouce plates, other than they were designed to fail. So I ditched the T-bars and got some 2"
                  U-channel and made a jig to build pit frames that are one piece and extend all the way to the vibration dampeners. We also beefed up our support brackets, cuz they too seemed to be designed to fail. It's been about 5 years now without a pit issue.
                    That's pretty funky mate I like it... see this is why I worship you guys being such a newbie compared to you I wouldn't have thought of that...
                      Sorry, I didn't make it very clear. I was talking about the bounce board mounting brakcet that's bolted to the side of the machine. This was before the brackets with the longer legs that rest on the lip of the side of the machine.
                        [ATTACH=CONFIG]2029[/ATTACH]
                        The bounce board bracing has evolved from 1 channel and 3 angles to 2 channels 1 angle and 2 T-bars . Each one presented failures at the end of the bracing.
                        It just seems that something like you've done or staggered bracing or adding shock absorbing material would prolong BB failure.
                        I do like the middle brace as it ties the 2 1/2's together which should spread the shock over both boards.
                        What size steel did you use?
                          oh in that case, i added one inch and 3/4 unc bolts instead of the fiddly, easy to round off, 3/4 unf bolts (5/16 dia- 1/2 inch spanner)
                            2 1/4" X 1" X 1/8"...Stahl's sells them to replace your T-bars. But this didn't solve my issue with broken bounce plates. I tried extending them in my R & D. This proved to be too much work cuz I had to build 37 of these. So I punted on that idea and went to a welding shop and had them made the correct length. (47 5/8") The center support is just a piece of the same channel. The extra thickness is there to fill the gap cuz it had to be bent.
                              We use channel on ours with 5/16 bolts also. This has worked well for us.
                              Peanut
