I am currently rebuilding a Westinghouse B/E gearbox and I can't seem to remove the snap ring (919-000-700) so I can get the worm gear out. Anyone have any advice on how to remove it?
Westie B/E gearbox
The snap ring is actually holding the bearing in there,after you remove the 3/8"nut from the end you drive out the worm with the rotor on it. A crappy bowling pin head will do,put the head on the threads and whack the pin butt with another pin and it will eventually nudge it's way out.70's MP/PBL/LBS,Q-Score
Prolane Walker sport
Snap Ring Pliers
I grind a 10 or 11 inch needle nose pliers to fit for just that.
You mean bearing?
Sorry, You Just need a Better Snap Ring Pliers.......Last edited by felix; 03-19-2012, 02:32 PM.If at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.Fields
Originally posted by interwhat View PostI am currently rebuilding a Westinghouse B/E gearbox and I can't seem to remove the snap ring (919-000-700) so I can get the worm gear out. Anyone have any advice on how to remove it?
if you go to the qubicaamf customer portal, you can download the Westinghouse manual.
http://customerportal.qubicaamf.com/...2fDefault.aspx
