Does anyone have a measurement they find works best from between the distributor carriage support casting (070-006-688) to the bin assembly? Also what height do you set your distributors on the channel support weldments?
Distributor measurements
Originally posted by clutchplate View PostI like my distributors as low as possible. Just make sure the trip arms dont hit the bin stringers.
