i have amf 90xli with the metal frame for the bin assembly and i have a lane that is double shuttling the 7 pin i replaced a side tube long because it was bent now everything seems to be straight but its still double shutting???
double shuttleing
Pin holders ok? Is the bin strap broken or missing? Have you serviced the shuttle rod? Also check the distance between shuttle and bins with the 6519 guage. These are a few things that can cause a double shuttle.
One thing I recently did was replace ALL the springs on my shuttle drive rods, I was getting a bucket load of double shuttles no matter how I adjusted the shuttle, I noticed most of my springs were about 5 1/2" after changing to the proper 6" springs all good very very few double shuttles.....AS REQUESTED....The all new and VERY improved "super cool" Pin_Head with super hip shades.....
Originally posted by oppel View Posti have amf 90xli with the metal frame for the bin assembly and i have a lane that is double shuttling the 7 pin i replaced a side tube long because it was bent now everything seems to be straight but its still double shutting???
Originally posted by rivmike View PostWhen the table goes up (right at shuttle) what is the distance between the bin and the cups? The cup ears should be touching the bin bumper stems or whatever you would call them.
The problem you are seeing with the shuttle spring is because the spring has 'taken a set'. When the spring is compressed to solid height (compressed all the way), it takes a set and won't return to its' original length. This has recently been corrected with a new spring that will not take a set like the old one did.
The old spring (070006306) is still available at this point (but I don't expect it will be for too much longer). The new spring can be purchased either as a complete assembly (088001631), or if you wish to purchase the necessary components separately, the spring is 088001632, and the stepped washers are 088001630 and 629.
