Helping out a center that is known for dropping pins all the time throughout the entire house. Pin just falls forward out of cup as its spotted. I put on a new cup and problem is gone. Visually the cups look fine but the adjusting bolts at the bottom of cup are fully tightened yet the gap is correct. I helped out at this center a couple of years ago and we started replacing cups as needed. I am now at a point that I told the owner we are going to start on lane 1 and change all the original cups. My question to all of you is has anyone ever seen this type of problem with cups and there is no apparent rhyme or reason
strange cup issue
If the adjusting bolt is all the way tight yet the gap is still too wide its possible the tips of the cup where you measure the gap have spread apart. It could also be twisted as said, run into a few of those myself.
Originally posted by clutchplate View PostHelping out a center that is known for dropping pins all the time throughout the entire house. Pin just falls forward out of cup as its spotted. I put on a new cup and problem is gone. Visually the cups look fine but the adjusting bolts at the bottom of cup are fully tightened yet the gap is correct. I helped out at this center a couple of years ago and we started replacing cups as needed. I am now at a point that I told the owner we are going to start on lane 1 and change all the original cups. My question to all of you is has anyone ever seen this type of problem with cups and there is no apparent rhyme or reason
Never had that issue with the cup gaps but I've pulled NUMEROUS cups that dropped pins intermittently. Cups were not warped nor did they show ANY signs that anything was wrong at allAll I want in life is to turn wrenches and climb around pinsetters/pinspotters again :/
Originally posted by Rep View PostNever had that issue with the cup gaps but I've pulled NUMEROUS cups that dropped pins intermittently. Cups were not warped nor did they show ANY signs that anything was wrong at all
Or of course the cup is just rubbish and a manufactuning blem
Had that problem on lane 16 this morning. The cup looks brand new. I loosened the adjusting bolt at the bottom to where I could turn the bolt by hand, and the problem disappeared. I'm wondering if having the bolt tight has a tendency to twist or mis-align the cup? Don't know, but it started to set the pin normally.Leyton at Tahoe
ok so just playing around this morming i took a normal brand new cup with a bolt and checked the gap and sure enough it was correct so then just decided to tighten bolt and it closed the gap then reopened the gap again as i got the gap closed and put more tention on the bolt. i bet that all the cup bots are so tight that its doing the same thing in that center and its springing the cups. just an obsevation from today hope it helps.
On a lane with a bad cup, removed bolt and problem was the same. Decided to remove the cup liners and problem went away(at least for today). I started removing cup liners across the house, machine is a little noisier when shuttleing pins but pins slide right into the cups. The reason for removing liners is to let the pin sit in the cup a little deeper. So far so good.If it cant be fixed with a hammer, use a bowling pin.
