well I had one snap below where the upper bolt is welded in, I welded it back and it pretty much melted the contact cement off so the rubber is barely hanging on. I'm sure your method is as I said "safer" and nicer, since some of the rubber melted as well. I'd love to be able to replace it, I was just asking what you are supposed to do after you get it separated, since I'm not aware of being able to purchase a new rubber from lifelong.
cool. I'll be ordering some of these for sure and give king's method a trial while I wait for them to get here. What are you using in your parts cleaner King?
Had a two of them out a couple weeks ago, i sprayed them with gumout carb cleaner and wiped them down good then took some 80 grit to them to prolong replacing. So far so good.
Charley
