At the University the students put in a spare table, I finished the installation went through all adjustments,
when the table is lowering to spot the pins the cups seem to bind they turn over hard and the pins all fall
over.I changed yokes and still have the same problem,no cups are rubbing the yoke, the cam followers are all
in good shape,replaced the legs nothing seems to be binding, the only thing I have not tried is changing the
lightning rod.Is it possible the table casting could be bad? I've never seen this before.It's hard to believe 2 yokes could be bad,but I guess it could be possible.
If anyone has ever experienced this I'd appreciate it if you would tell me what you did to resolve the problem.
Thanks Jim
Thanks Jim
