82/70 ss single board doest not feel for pins
  • 82/70 ss single board doest not feel for pins
    help a masher mechanic out on a 70 issue...have a lane that every 10 or 15 frames it tries to spot pins on standing pins, have not caught what ball lights are on yet.....any suggestions?
    thanks in advance
    john
    Need to narrow it down by determining if the machine is setting pins on top of pins when there are pins in the scissors (instead of respotting them), or is the table going into a long stroke when it should be running a detecting stroke.
    Two different scenarios and probable causes.
      I like the bruns. wording for the masher guy
        ok turned out the spring bracket on the bottom of the spot solenoid had turned and was not providing enough tension to raise the latch always.....thanks guys
