The starting point if you do not have the gauge is 7/8" from the shuttle tubes to the rear channel of the bin, on both sides. Or if you have the gauge use it like this...
The front to back of the shuttle is adjusted by this rod end, not the rod. Unscrewing the rod end will make the shuttle sit further back.
The starting measurement if you do not have the gauge is 1-23/32" (that's a goofy measurement but that's what my book says) from the rear shuttle tube to the rear bin channel. Or if you have the gauge use it like this...(it should easily fit in there straight up and down on both sides)
The square of the shuttle is adjusted by this spring. Ideally it should be in the middle hole but if the shuttle is not square to the bin this spring can be moved to another hole. For example, if the shuttle is further back on the 10 side move the spring toward the 7 side, this will pull the shuttle over to the 10 side and pull the 10 side of the shuttle slightly forward.
This is just to give an idea of the gap between the cups and pins when the table goes to spot. Remember, the greater the gap the more likely it can double shuttle.
Also remember, these adjustments and measurements are starting points only and can be affected by various things. Some deviation may be necessary. The bottom line is it should smoothly and consistently shuttle one full set of pins when they are all pushed forward in the bin locations.
