DurabinII Index CamII and ArmII
  • DurabinII Index CamII and ArmII
    Hi guys,
    I have tried looking and for the life of me can't find the part numbers, does anyone know the part unmbers for the new Index CamII and Arm II for use with the DurabinII, I would really like to try it as I have a few lanes causing a world of hurt with poor feeding into the corners, you get one side perfect teh other side won't feed smoothly....
    Have you tried the washer trick?
      Yeah did that on a few lanes already still hard part is getting the 7 AND 8 pin perfect at the same time getting the 10 AND 9 right, often you get at the corner pockets when the pin drops in on some of my lanes the head of the pin gets caught up on the trip forks
        I bow the bin stringer in on the 7 and 10 to give aliitle more leeway (my dist. are low) I also take off the first set of trip arm rollers (that's were they get caught on the corners) I put an x washer under the front trip arm bumper to help with the set of rollers missing.
          The Cam II upgrade kit is not yet available for resale. When it is, you will be able to order it under part number 612 088 501
          Regards,
          Billy T
          bthompson@qubicaamf.us
            Will the cam and arm come together in the kit Billy?
              The kit includes the cam II cam, the cam II arm, two aluminum spacers for either side of the cam and a new thrust washer for the pinion.
              Regards,
              Billy T
                Any ideas as yet to a release date???
                  Not at this time
                  Regards,
                  Billy T
