SIMPLIFIED CLUTCH ASSEMBLY
  • SIMPLIFIED CLUTCH ASSEMBLY
    Has anyone tried this clutch? Also does it work better and if i order one will it give me instructions on assembling it??
    Not worth it. I got 2 of em once and every week i had to tighten the nut more, eventually completely compressing the spring and it wouldnt work anymore. The original clutch design is pretty rock solid, there really isnt a need to change it besides those of us who like the roller clutch plate
      OEM is the way to go, you put them on and get them lubed and set and that's pretty much it- for years. I haven't tried any other clutch but I would imagine the roller clutch works well too.l
        I got a full box of used ones if that tells you anything.
        Mike
          I will add to that. We recently received a few well used distributors, with OEM clutches on them. I put them all on machines and when I did I just gave them a quick clean and lube and have since had no issues at all with the clutches, I probably didn't need to even do that with them.
          Yeah, the OEM clutches are THAT good.
            Agree to all the above.
              They don't work cuz the "D" shaped hole in the outer plate liked to lock on to the shaft...hence loss of tension. Also the spring liked to spin on the outer plate, essentually making another clutch...and again loss of tension. All of this led to what SLB descibed above. But cranking them down was not the solution. I was able to make these work by boring out the outer plate, welding the plate, spring and nut together and adding a set screw to the nut. But welding spring proved to be a challenge cuz you lose the tinsile strengh of the spring from the heat. This was actually the prototype to the clutches that I developed that we currently use. I just hated the maintenance of tearing the OEM clutches down, cleaning and lubing every three months. My maintenance now entails replacing the pinion sleeve every year or two...That's it. No lubrication, no cleaning. Leaves me much more time for other things.
                we have 5 or 6 QAMF Simplified Clutches that have been running 1 1/2 years and do not have any issues with any of them. We lube the stop blades with a dab of STP Oil Treatment every 3-4 weeks and some of that film migrates onto the clutches. Maybe that's why they work for us. We did have 2 other style of simple clutches installed, and had problems with both of those and removed them.
                  Roller clutch for the win!
                    I second that have had mine on for two years and pulled one the other day just to see how it looked. Almost new, with the enviro bushing those are almost bullet proof.
