No Cycle Start
  • No Cycle Start
    Have Vector Scoring, 8270 SS with XOP board. Tried cycling with push button and ball detect both not working. Turn pinspotter off then on, continuous sweep or cycles when turned on. Can't run sweep from SA switch. At a loss. Help!
    Also tried chassis from working lane and same results. Tried unplugging AMC cable then plugged back in, cycles thru. Rebooted computers. Nop change. This started after mechanic did routine PM oil and grease.
    Did you try another board?
      Tried working chassis from next lane over. Same results.
        T.ried chassis from working lane same results
          Used chassis and board from working lane. Same results.
            If I run sweep down to guard then turn machine off and on it completes cycle. Machine front desk switch is off and not in instructomat position.
              Remembered that a diode on the mother board is part of instructomat circuit, but not sure which one. Have disconnected the two diodes and capacitor at the front desk, but still stays in sweep lock mode. Where else can I go?
                There is a diode on the mother board of the SS chassis that is part of instructomat circuit. Have disconnected both diodes and capacitor at front desk, but still in sweep lock mode. Where else can I check?
                  I'm willing to bet one of your manager control wires are grounding out on the frame of the machine somewhere. Most likely when PM and lubrication was done he accidently knicked a wire and caused it to ground out. To test unplug the a&mc cable and jump the two pins next to each other in the middle row on the machine side of the plug to turn the machine on and then try to cycle it and see if it works normally.
                    Instructomat would not allow you to run the sweep with the SA. Flipping the managers control off/on with one version of OmegaTec (a jumper) will cycle it from the front desk switch. It wouldn't if in instructomat. I'd suspect more of SA, SB or wiring to them. Perhaps a bad sweep power switch on the BE control box?
                    You can look on the vector camera to see if the diode lights when a ball passes, the another diode by the relay when it's supposed to cycle.
                    If you want to eliminate external sources for cycling issues, unplug the A&MC cable. Use a jumper to connect the only 2 terminals in the middle row of the 3 rows that are next to each other. The machine should come on, and you have cycle control with the button in the back, or cushion switch.
                      Another simple thing could be your offspot switch/wires causing it to stay in instructomat.
                        Tried jumper. Machine comes on and sweep runs continuously. No cycle function.
                          Turn pinspotter on sweep runs continuously. Zeroed then sweep stops. Press cycle. Run sweep to 1st guard and turn off and on, machine completes cycle and spots new set of pins.
                            Made mistake, turned machine off and on not sweep switch.
                              Maybe off spot switch/wires related.
