Xli and Vector scoring
  • Xli and Vector scoring
    Doing side work at a center that has XLI's and Vector scoring. After ball passes detector it takes 5 seconds for the sweep to drop. Lots of deadwoods. Is there any anything to fix this problem?
    Depending on the speed of the ball when passed through the ball detect. There is a slow ball fast ball setting that you can change around in the dator or POS computer. We have ours set at 300 milliseconds for fast ball and 2500 milliseconds for slow ball trigger. Our ball detects are set in front of the masking unit legs due to balls damaging the ball detects when they were mounted on the kick backs. You may want to play with the fast ball trigger a little depending on where your ball detects are mounted. You will have to reboot the scorers for it to take effect for the changes.
    Live The Dream.
      cool, i will give it a shot, thank you
