Table Drive
I tighten until it does not turn reel free to set the bearing in the race...then i back off until it turns free....then I torque the jam nut on back as tight as possible - recheck for free movement!
Tighten as tight as possible.. over tightening should yield free movement if correct parts being used. Similar to how people omit the correct washers for the table drive clevis rod end... too tight and it doesnt move.. well fit the right stuff and you tighten it as much as you like...
I tighten it until I can't turn it by hand then back it off slightly. Most of the time it will still turn when tight- no issues here with them. Also when it's apart I clean all the grease out of it then re lube when assembled.
Originally posted by Tablejam View PostI tighten it until I can't turn it by hand then back it off slightly. Most of the time it will still turn when tight- no issues here with them. Also when it's apart I clean all the grease out of it then re lube when assembled.
