new more solid parts
  • new more solid parts
    hey guys just want your oipinion and i know im opining a can of worms here but where i work our owner owns a huge metal shop here in San Fran and can litterally make anything i want. Ive been having him make a few things for our center with pretty good success. i have a few pics but just cant seen to get the links to work on here. if any one could post them that would be awesome. we arent looking to sell these things as most of them are in a trial stage but can you think of anything in our machines that could use some beefing up?
    Plows
    Pit Support Brackets
    Pit Angles
    Bounce Plate Support Angles
    Distributor Weldments
    Cushion Weldments
    Cushion Hanger Weldments
    Pin Guides
    Butt Guides
    Bin Actuators
    Bin Stringers
    Outer Distributor Clutch Plates
      I would say mostly pit and bin stuff, the parts that really get beat up.
      Pit supports/angles
      Bounceboard channels
      Both plows
      Cushion weld
      Cushion boxes
      Pin guides/butt guides/stringers
      Shuttle straps
      Can't say I've really had any abnormal breaking of the rest of the parts in that list
        Shuttle tubes... stop the pricks bending and twisting
        Stronger ring tubes!!! <- i'm lookin at getting these made locally for strength and lower price
          How about the shuttle mounting brackets? Also, the part of the kidney that the pins ride on. A little over a year ago we straightened all of pin contact area as it was wavy, but it didn't last very long as it is wavy again.
            Hey TJ, Have you tried Stahl's shuttle straps?...Indestructable
              I do not recommend using them - there can be clearance issues with them - they can hit the cups while shuttling
                Really???...OK, then keep replacing those AMF pieces of crap when they break.
                  I make my own
                    If you don't have pins in the table they break less - it takes less than 5 minutes to replace....the shuttle straps banging into the cups when shuttling is a far worse issue than a broken strap
                      Actually my boss just ordered some but I haven't put them on anything yet. I looked at them and they are definitely beefier looking. I'm not worried about shuttle strap-to-cup clearance as they don't look any taller than the AMF ones and I don't have any cups that would be touching them- so not an issue here.
                        AMF straps are horrible. I started installing Stahls and not one has broke.
                          You lose less than 3/8" clearance. Total replacement time...0 minutes...Cuz they don't break.
                            Why did AMF change the style of the shuttle straps from this shape ] ? The current style always break where they're stressed and bent on the ends in manufacturing. It seems to me that the old style wouldn't have that problem, although I've never used them since they've been obsolete for a long time now.
                            9th Amendment!
                              The new rounded style also makes it hard to get a good grip with a socket.
