Has anyone tried any other bolts for the front rollers? Like larger inhex heads or torx or something else? Im getting sick and tired of stubborn bolts that wont come out or the heads get stripped. Can't even use an impact because of the bit thickness it just snaps. Is it just me or are the bolts in the front roller a complete joke? Not to mention dangerous.
Front roller bolts
Front roller bolts
Hi guys,
Has anyone tried any other bolts for the front rollers? Like larger inhex heads or torx or something else? Im getting sick and tired of stubborn bolts that wont come out or the heads get stripped. Can't even use an impact because of the bit thickness it just snaps. Is it just me or are the bolts in the front roller a complete joke? Not to mention dangerous.Tags: None
hit the bolt with brass/deadblow really freaking hard then it turns out easy peasy lemon squeezy. how have you been doing it?
also chasing the threads is pretty much required make it nice and easy next time too.When you know what to do, everything is easy.
Smack them hard with a hammer and they normally loosen up nicely, yes. But some rollers dont play ball. Now considering the manufacturer states those bolts to be torqued to 400lbs/in... there is no bit on the market rated for that.. so what the hell?
Got any spare table/sweep rods lying around? Whip the rod end off and you have a 3 foot bar to slip over your allen key. If the nut head is dead, weld a 9/16 bolt or nut to it and get the socket on it, the heat from welding helps it pop
Originally posted by MarkyB View PostGot any spare table/sweep rods lying around? Whip the rod end off and you have a 3 foot bar to slip over your allen key. If the nut head is dead, weld a 9/16 bolt or nut to it and get the socket on it, the heat from welding helps it pop
whacking, heat and extra tube for leverage is going to be the way to go. When reinstalling I clear the threads then use the same size bolts but get them from grainger and use blue locktite. Have not had one back out yet and they are easier to remove.Sometimes we have to do stuff to get by....Just go back and do it right when the "by" has passed!!
