Radary Plus foul lights 15 and 16
  • Radary Plus foul lights 15 and 16
    Here is a link of it, video didn't capture very well on my camera, but that's why I'm going to describe it as well.
    Foul lights on 15 and 16. 16 fouls after you remove your hand and 15 blinks faster when you break the beam. 15 never actually fouls. I traded F2 and F3 with a working pair and tried to realign the sensor. other than swapping the board out what else can be done?
    That's all you can do. There is a problem with the board - I see this problem all the time with these units. It won't be the fuse, the relay for 15 is never pulling in.
      Amen Jon. The units are fantastic when they work but when they go they go big time.
        This is why I use the Zot replacement for these. They are all modular allowing only the troublesome component to be replaced instead of the whole shebang. They fit into the existing housings with no problem.
          The emitter/detectors should have been connected via a header vs. soldered in. Plus the flex cable they used is crap - I have a far better cable I replace these with. Plus the transformer mounting is terrible. Glue just doesn't cut it in a device that people can kick the crap out of or drop a bowling ball on...
            So pretty much when they fail you are saying that you should just replace them and there is no fixing them? I have another unit that is also malfunctioning. here's 17 and 18.
              Not at all. I'm sending you a P.M.
              Jon
                My beef with the unit is that you can't order components separately. You can't get just the PC board. Or the Optics. Or the transformer.
                  A change is coming....Not sure when
                  Regards,
                  Billy T
                  bthompson@qubicaamf.us
                    Would this be the Radaray Plus..Plus or the RadarayEDGE?
                      Ahem.... Never say never....
                        Uhh, I don't think he did.
                        Regards,
                        Billy T
                          Are these units supposed to be linked on the pair? what I mean is on 13 and 14 I can foul on either lane but both lanes perform foul cycles. not quite every lane in the house does this, but a lot of them foul this way.
                            If the signal wires are connected incorrectly that will happen.
