rear roller tip
  • rear roller tip
    first a tip than a question . had a rear roller retainer break off a machine [ not the fist time ] during league my emerg fix is to take a tie down rachet belt feed under paddle brace place hook around pully shaft then other end attach above center of machine and ratchet belt bring roller back to center of retainer holding possition works great and can run machine for days or weeks if u have before replacing pain in the but retainer ,, now for question i replaced retainer as i have done at 6 times before over the years howerver this time after replacing the roller wants ride 2 outer side of machine cousing belt pulley 2 ride against machine and and wear on pully and locking bolt i just pry roller back over and rides fine 4 a few days then have 2 pry back over might have rubber retainer insert in backwards going 2 check next busy with tournament right now any suggestions guys thanx and good luck if u ever need this emergency tip works great maybe should have left new retainer off and just stuck with temp fix [ lol] chris
    How did you attach the new bearing retainer?
    If the rubber piece in the retainer correctly?
      thanx king i ground off old retainer drilled the 4 holes in and bolted in possition then glued a new rubber rubber insert in place
        I usually do not glue the rubber retainer
          Not saying that is the I bolt mine in place
            I think he's saying he glued the rubber into the bracket King. He said he drilled and bolted the bracket in.
            My question is how did you know the retainer broke? one time out of 5 maybe I heard it making a horrible noise, the rest of the time it just cuts its self off and falls down. So your roller is walking out of the retainer and pulling the pit sheave against the kickback? front roller not giving enough tension maybe?
              I understand what he glued - I have never glued the rubber piece - makes it too hard to get out - even on the ones I have replaced the metal retainer
                thanx guys i did bolt in place, the rubber insert i think put in backwards because one side is flat and other is cuerved smooth and i think the curved side should b placed inward 2 match the roundness of the retainer alowing 4 aflatt surface for bearing 2 rest heading in about an hour will check ,, just lightly glued rubber in place to hold rather than bending little metal edges down to hold in place hope this clerafies will let u know tanx chris,,as 4 catching problem i did not it did cut off however 5 min rolloer replace and emergency cobble trick was able 2 keep full house of bowlers wiening about loosing jackpots insted of broken machine [ lol]
                  Chris, are you saying You let the roller shaft rub on the hook? Does'nt wear through?
                    thats right applied alittle oil on hook and theres not much pressure on on it your only pulling it back about 1 inch my strap has plastic covered hooks and it barely wore on hook at all had in place 5 days and machine was used 3 shifts a day 2days where 4 counting kids didnt have time 2 repair so a little oli and no problem as i said this is not the first time ive used this trick works fine only it makes me a little bit of a procratinator when to replacing the retainer ive gone well over a week before not lazy ,just busy
                      Great way to get the machine running!
