XLI elevator strips
Originally posted by mechanic8230 View PostSlop in the pinwheel equals pin jams to me. That strip is about 1/4" thick so without it the pinwheel drops lower to the distributor orientation pan. Also without it you have steel riding on those plastic pinwheel rollers.
There's no ring on those, the wheel itself sits on rollers. Just make sure the pin the rollers are on isn't sticky, i had a bunch of them freeze up, grey shavings everywhere. I think there's some sort of rustproof coating on them from the factory if memory serves me, it's been a while.Charley
With the standard pin wheel rollers and strip you will still struggle with orientation. We manufactured rollers which were 1/8th inch larger. These had the effect of raising up the elevator and also making you able to keep the elevator slop to a bare minimum! Vantage now sells larger pinwheel rollers, but QAMF doesn't.During your daily elevator cleaning always check the condition of the grey strip and repair as needed - best working practice.
- Likes 1
I am still really confused as to what strips we are talking about here, I always thought the steel ring tube itself ran on the pinwheel rollers??? the larger diameter rollers, how much larger are they? cuz surely if you go larger they wouldnt fit inside the ring tube?
Anyone have a photo of these said grey strips and where they go??
Cuz maybe this is the problem with my lane 9, seems like the pinwheel is too low and head first pins smack the rim of the pinwheel when the belly drops onto the o pan...AS REQUESTED....The all new and VERY improved "super cool" Pin_Head with super hip shades.....
Originally posted by Pin_Head View PostI am still really confused as to what strips we are talking about here, I always thought the steel ring tube itself ran on the pinwheel rollers??? the larger diameter rollers, how much larger are they? cuz surely if you go larger they wouldnt fit inside the ring tube?
Cuz maybe this is the problem with my lane 9, seems like the pinwheel is too low and head first pins smack the rim of the pinwheel when the belly drops onto the o pan...If it cant be fixed with a hammer, use a bowling pin.
Originally posted by Tablejam View PostThe pin elevators on machines newer than yours up to the EDGE machine have a pinwheel only with no ringtube. The wheel itself actually rides on these rollers. Imagine taking the ringtube off the elevator wheel then moving the rollers to run around the inside rim of the elevator wheel, that's basically what it is except the rollers are different.
So pretty much like on an old Brunswick A/A2 how the wheel hubs sat on the outside of the pinwheel etc??AS REQUESTED....The all new and VERY improved "super cool" Pin_Head with super hip shades.....
Pin Head...........on an 82-90xl there is no ring tube. The pinwheel itself rides on the interior cut out on 3 larger plastic rollers and there is a plastic strip that is riveted to that interior ridge to help keep things tight. Also there are no pin cleats or brackets on this pinwheel to come off. If you can find an 82-90 manual you will see what we are talking about.
