Replacing pinwheel strip
  • Replacing pinwheel strip
    What is the best way to replace the riveted plastic pinwheel strip on Xli?
    Remove the old one first. Sorry, couldn't resist. What are you wondering about?
    Regards,
    Billy T
    bthompson@qubicaamf.us
      Do I need to remove the plastic rollers or do I just put a little on at a time and rotate the pinwheel.
        Yep, you got it Clutch. Tap in place and rivet and then go a little at a time till you get to the end and then trim and rivet and you are done. Be sure you get it tapped into place good though.
          Thank You
            My pleasure my friend.
