Table motor overheating
I have 82-70 machines with SS chassis, Omega tek with expanders. I have a chassis that overheats the table motor. I have changed all the C1 pins and the table relay. I have also recrimped all the ends for the wires on the table contacts. No other chassis overheats this motor.Tags: None
The table relay and contacts are new. I completley replaced the unit. I replaced all C1 pins and some C2A pins. I tested the rest of the C2A pins to make sure they had good crimps and snug pin connections. The table motor is a Westinghouse with a Solid State switch. That is also new. If I put another chassis in the machine it doesn't overheat the motor. Only this chassis does it. I'm not sure what else is in the table run circuit (chassis side) that is left for me to try. Thanks
swap individual parts with known good ones (taken from another lane that has no issues) until the problem moves. Dont assume just because a solid state switch or contact is new that it works too. Ive gotten faulty ones before. What switch are you using?Giving bowlers less to complain about, one lane at a time
Originally posted by slb785 View Postswap individual parts with known good ones (taken from another lane that has no issues) until the problem moves. Dont assume just because a solid state switch or contact is new that it works too. Ive gotten faulty ones before. What switch are you using?
Do you have a jumper cable for your motors? Handy to have an extension cord for the motor plugs and easy to make up. Lets you plug your sweep plug into the table motor and vice verse. I plug the sweep plug into the table and run from the SA cam switch. Let the table cycle half a dozen times while feeling it for overheating (or if it cuts out). This eliminates the motor from the motor circuit. Swapping the chassis with another lane will narrow it down to motor circuit or chassis issue.Failed safety course.Question #1:In case of fire what steps do you take? Apparently 'Friggin long ones!" is the wrong answer.
