1. The hole for the yoke spring over time wears out
2. I use the 070002577 Stud that goes through the table and drill through the leg
3. Grind off old hole
4. I start with a small drill and work my way up to a 5/16 - drill hole as close to web in table leg as possible
5. Install the 2577 stud through the hole with a lock nut and flat washer on the back
6. Easier and more permanent than swapping table legs
