The second one when you put it on the machine the backend starts but won't cycle, when you turn on the sweep you get a continuous sweep run, when you shut off the sweep and turn on the table you get a continuous table. Thanks for any help.
Mp Chassis
Mp Chassis
In need of some help. I have two mp chassis that won't run on the machines. First one its in the chassis i've switched out the mp board, the 3 cube relays, and have checked all the wires in the c1 plug. When you put it on the machine won't turn on.
The second one when you put it on the machine the backend starts but won't cycle, when you turn on the sweep you get a continuous sweep run, when you shut off the sweep and turn on the table you get a continuous table. Thanks for any help.Tags: None
#1 Chassis check mask switch & plug, or Mgrs control Switch
#2 Chassis try a working Bd.If at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.Fields
Check CB"s
#1 BE relay (old style) can be pushed in with a pencil to turn BE on.
#2 T4 glass coils
T3 Mask/Scoring
T2 Mgrs Control Circuit/SpotLast edited by felix; 05-31-2012, 02:20 PM.If at first you don't succeed, try, try, again. Then quit. There's no use being a damn fool about it." -W.C.Fields
After reading you post, several times, I figure these chassis are not "Known Working", and they were on the "Other Bench" attached to the "Healing Wall". Been there, done that.
On both you could try a simple reset. This has worked for me many times.
On the first chassis you might try tracing the wires inside the chassis to make sure one or more of them are not nicked and finding a ground. Had a couple of those.
On the second chassis a reset might work, also I have used the ball stepper for a soft boot.
Swapping boards with known working is always a good call, as is cleaning the contacts of the boards, including and especially the grounds.
If you have the boards with the button batteries, change them! Those little buggers are a PITA sometimes.Necessity IS NOT the mother of invention. Laziness IS the mother of invention.
