82-70 wireway diagram
Okay....i officially feel a little more retarded this post.........I cant see the TAB or the TAC.....
..... It has been a very long two weeks with only half of a day off in the past 14 days, any chance you could dumb it down a lot for me?
TAC is by the capacitors. Small board a little larger than a business card. All it does is extend the wires from the table cable to the c2 plug at the chassis. 10 terminals numbered for the pins, a ground terminal and 2 terminals labeled SW for the gripper protection switch. If you have eliminated table wiring this can all be removed. I made 2 jumpers - one for GPS and one from a pin position to ground at c2. This allowed me to remove all the wiring from c2 to TAC, the TAC itself and the table wiring.Failed safety course.Question #1:In case of fire what steps do you take? Apparently 'Friggin long ones!" is the wrong answer.
