Mp Chassis
  • Mp Chassis
    Looking for some help. I have a mp chassis i have tryed the mp board, relays, circuit breakers and contactors. The machine will zero okay the backend will run when I turn on the switch. If I turn on the sweep switch on the back control panel I get a continuous
    sweep run. If I turn on the table switch on the back control panel I get a continuous table run. Any ideas?
    Have you tried the chassis on another lane? If so does the problem follow the chassis?
      Yes I have tryed it on another machine. I'm sure its in the chassis
        So what exactly does it do when you fire up the machine with your three switches all on on your back control panel?
        Does it run both sweep and table until it interlocks?
        When you say you tried the board, relays etc. do you mean swapped out with another chassis?
        Just trying to get a better picture of exactly what its doing?
          If I leave the switches on it will go into a inner-lock. If I shut the switches off when i turn on the table it runs continuous, it does the same thing if I turn on the sweep switch.
            Hmm, contactor coils grounding? Been awhile but varistors? Has anything recently been done to the C2 plug on this chassis? What happens if you turn on these switches with no board in the chassis at all?
              Just something to try. Open up the control box and hook a wire from frame ground to the, I have magicscore scoring, black wire on the cycle button. For me this little thing stops a lot of werd promlems.
              AMF DOCTOR
              The doctor makes house calls.
