70 vs 90 Distributor Question
  • 70 vs 90 Distributor Question
    Went from 30's to 90's here so not sure about this... Is the distributor on a 70 the same as the one a 90xl? Found some real cheap spares that came off of some 70's that I thought I would pick up if I can use them..
    Again, thanks in advance!
    Dave
    They will work....buy them if they are a good deal.
      Buddy of mine says he will take 50 a piece for them, I would think they have to be worth that if they are decent!
        The support castings alone are worth $100s. Id buy em
          They are more or less mechanically identical. The only thing that would be different from a 70 to a 90, is on the 70's you'll run into old designs of certain components that are no longer made, but function the same as the newer version of the part in question. At $50 for the entire assembly, you're damn near robbing him.
          On a side note, 30's to 90's...APPLES AND ORANGES!!!!!!!!!! Get used to not doing much.
          Change the chassis, is not the answer.
            $50 is a steal, even if they have problems. Brand new distributors are around $1,200-$1,400.
              Thanks!! I thought so, but wanted to confirm.. Ill scarf em up!
