GE Combo motor runs backwards
  • GE Combo motor runs backwards
    So out of 24 lanes we have one lane with one GE combo motor on it. Not one lane with a pair, just one motor. LOL So after 5 seasons here i decided i better quit pushing my luck and get the spare stator for it going. I'm guessing it has been rebuilt cuz the inside shroud is missing and it's painted grey. Also the wires are all black instead of red, blue, yellow and black. However, they do have colored bands on them indicating which is which is which. I've compared the two and they are wired exactly the same but the spare runs in reverse, with no other issues, it starts and stops just fine. I am thinking maybe a couple of the colored bands were put on the wrong wires. If so, does anyone know which two you would switch around to reverse it?
    Charley
    sounds to me like the wires are labeled incorrectly. Use a multimeter and check the resistance of your windings. your start windings will have a resistance of 4-5ohms and your run windings will have around 2. numbers wont be exact but the start windings resistance should be roughly double what the run windings are. Once you figure this out you can make sure the wires are labeled properly. Red and black for start, yellow and blue for run. then double check that everything is wired properly. I had a combo motor that ran backwards and found that it was wired up wrong
      Your best option is to switch the X and Z wires on the motor receptacle - I ran into this on a machine once and it turned my hair gray way too fast - the stator you pulled off probably needs X & Z swapped also so you don't experience a repeat of this on another machine!!
        i use all GE motors in my center and have had this problem before its not a major issue, if your using a solid state start switch on the motor then just reverse the wiring the start winding, should be red and black from the solid state start switch
