Pincup yoke help!!!
Pincup yoke help!!!
ive got a lane that everytime on spot the whole yoke jerks really hard, making the pins shake and the 8-pin falls everytime. all spring are in place and seem ok.. no play in the lightning rod. when i move the yoke by hand it feels smooth and normal. need to fix this asap!!!Tags: None
Sounds like a cup is catching on the yoke on its way forward. Crank the table into spot mode and check all the cups for clearance.A person who never made a mistake never tried anything new.
- Albert Einstein
I'd check the spot cam, roller bearing, and all up-line linkages.
I've had instance where the cam shifted and the roller was rubbing the re-spot lobe.
PCWe leave our greatest mark on this earth with the quality of our craftsmanship.
