Poly V and weather
Poly V and weather
Has anybody else had this problem besides me? In the cold of winter some of the poly V dist belts were so tight that I almost could not pin them together with the belt tension spring off.I also had to run the distributor with no linear spring to keep the clutch at an acceptable tightness but as soon as the heat of summer showed up in my pit those same belts were now loose and needed the spring put back on or the carriage would stay all the way back after the 9 pinThis was a real bother as at the beginning of the cold,hot,hot cold of spring could not make up its mind the spring was on and off and on to keep the dist running right.
70's MP/PBL/LBS,Q-Score
Prolane Walker sportTags: None
Originally posted by keeth View PostMine do OK with the dry rag method but what pile of crud comes from out of the grooves.
Originally posted by Tablejam View PostMinus the shedding those are pretty good, too bad you can't get them no more.Sometimes we have to do stuff to get by....Just go back and do it right when the "by" has passed!!
