Second ball not registering on Scorer.
  • Second ball not registering on Scorer.
    I have recently taken over management to a center with AMF pinsetters(one week). I have years of experience with Brunswich but this is the first time in an AMF pit or house. I know that everyone needs the technical aspects and will fill in the info later. the only hint I can give is that the frame lights on the mask flash/blink when the pinsetter cycles after the first ball and subsequent cycles. My mech only has 9mos of experience, another 10+ mech told him to check the 'things' he already has. i wanted to start this in hopes of finding a cure today or next. i will fill in the tech specs later today. any help will be appreciated.
    Thanks, KW
    Lets bring back Bowling to its old glory, Together!
    First, need to know the following...
    What scoring system
    What type of chassis
      Most scoring systems require voltage signal from the second ball lamp to function correctly.
      Check your mask to chassis plug, and where the scoring connects to the machine.
      Sounds like a bad connection somewhere.
      If all that looks good, swap the chassis with the sister and see if the problem follows it.
      PinCup
        82-70's with Purrfect desk and Accuscore XL. I don't know much, yet, but if you ask - I'll find out.
          Thanks, the previous owner is coming tomorrow to give me some more assistance. I'll check the connections. I have been looking and I believe that the blinking 1st and 2nd ball lights is a sign to the problem. Also, the 'mech' on hand couldn't get the CPU from 1-2 to boot up on 7-8. the lanes 2 and 7 are the lanes that are experiencing this same problem, but from previous experience the voices in my head are telling me it is something simple like a short or bad wire.. BTW, been watching your posting for years, Thanks for replying.
          KW
            Accu XL requires 2nd ball voltage to score
            The bulb could be out or the chassis is not sending the voltage to the masking - or you could have a bad wire to 2nd ball
              That scoring needs a constant signal on second ball to score it, the blinking seems like a connection or chassis fault.
